| F47.1 | IAC valve (close end)
| | F47.2 | IAC valve (open end)
| | F47.3 | Wastegate control T
| | F47.5 | Self-shutoff control
| | F47.6 | Canister purge control
| | F47.9 | Cylinder 3/4 ignition
| | F47.10 | Cylinder 1/2 ignition
| | F47.11 | Cylinder 3 injector
| | F47.12 | Cylinder 2 injector
| | F47.13 | Cylinder 1 injector
| | F47.14 | Power supply ground
| | F47.15 | Ignition ground
| | F47.17 | Radiator fan control
| | F47.18 | TI monitor
| | F47.19 | MIL
| | F47.20 | Pressure exchange solenoid T
| | F47.22 | A/C cut relay control
| | F47.23 | Fuel pump relay control
| | F47.24 | Injector ground
| | F47.25 | Injector ground
| | F47.26 | Cylinder 4 injector
| B56.1 | Cam angle sensor (+) T
Crank angle sensor (+) N
| | B56.2 | Cam angle sensor (-) T
Crank angle sensor (-) N
| | B56.3 | Cam angle sensor (shield) T
Crank angle sensor (shield) N
| | B56.4 | Knock sensor (shield)
| | B56.5 | Knock sensor (signal)
| | B56.6 | Idle switch
| | B56.7 | Select Monitor (Rx)
| | B56.8 | Select Monitor (Tx)
| | B56.9 | A/C switch
| | B56.10 | Starter switch
| | B56.11 | Jurisdiction ID
| | B56.12 | Read memory connector
| | B56.13 | Test mode connector
| | B56.15 | Trouble code output
| | B56.16 | Engine tachometer output
| B58.1 | TPS (ground)
| | B58.2 | TPS (signal)
| | B58.3 | TPS (power supply)
| | B58.4 | Crank angle sensor (+) T
Cam angle sensor (+) N
| | B58.5 | Crank angle sensor (-) T
Cam angle sensor (-) N
| | B58.6 | Crank angle sensor (shield) T
Cam angle sensor (shield) N
| | B58.7 | TPS shield
| | B58.8 | MAF sensor pin 5
| | B58.9 | Park switch
| | B58.10 | Neutral switch
| | B58.11 | VSS
| | B58.12 | Ignition switch
T: Turbo models only
N: Naturally aspirated models only
1: 1990-1992 models only
| B48.2 | Power supply
| | B48.3 | MAP sensor (power supply) T
| | B48.4 | MAP sensor (signal) T
| | B48.5 | MAP sensor (ground) T
| | B48.6 | Oxygen sensor (signal)
| | B48.7 | Water temperature sensor
| | B48.8 | MAF sensor (power supply)
| | B48.9 | MAF sensor (signal)
| | B48.10 | MAF sensor (ground)
| | B48.11 | Control system ground
| | B48.13 | Power supply
| | B48.15 | Backup power supply
| | B48.16 | Barometric pressure sensor 1N
| | B48.17 | Oxygen sensor (shield)
| | B48.18 | MAP shield T
| | B48.19 | MAF shield
| | B48.20 | Transmission ID
| | B48.21 | Sensor ground
| | B48.22 | Control system ground
